yea that was 2 pulls. Is that what made it slew all over the place or just what gave the high number?
ok I isolated just the one run in the csv file. This looks alot better
http://i12.photobucket.com/albums/a2...r04/1086hp.jpg
Thanks. It was taken with 2.23
Mods in sig
100 deg here in houston
Ill give that a try
Hi TXZ0603,
The only WOT data I found in your CSV spreadsheet starting 1848 rpm ending 5983 rpm is from:
Line # 4778...rpm 1849...speed 29mph
Line # 4869...rpm 5982...speed 91mph
This is obviously a 3rd gear WOT session...
You will certainly be very pleased to note how accurate Brad software is when you will adjust your graph to 3rd gear and correct it with the SAE information...
Is your last Dynojet record in the low 600rwhp?
Christian
Is that vehicle weight you are using include your weight? Also why are you using SAE correction?
Ha! Hadnt noticed that. It was a long drive and I really didnt even think about it. My last DJ was 784 at 16 psi on meth with smaller turbos.
Yes I added my weight. I figured the SAE would be closer considering it is 100deg here and the function shows 77 deg without. Still a nice program.
1.1.2 has been released ... enjoy
How can I get the AFR and Boost gauge to work? Do I just need to rename my PID's to AFR and boost?
If there are logs that have AFR and boost in them and they arent showing up ... could I get someone to send me their email address via PM and Ill send them my email address so they can send me the uneditted logs so I can add the extra columns to the database and others can benefit?
Whew that was a long sentence but it is 520am ...
played with it, not satisfied with my numbers lol...then again, i had to fudge a lit of them to get the HP even close to right but then the TQ was low.
my fault though, was using the Ion RL(no cobalt lsj) and i had only 2nd gear pulls recorded so i set my final drive to 6:1 and told told it it was a 3rd gear pull.
nice software though! tempted to get some real pulls and play with it see if i can smooth out/raise the curves a bit
if you want to get me the info on the Cobalt LSJ Ill be glad to add it. PM me for the required info.
Fudging just a little can have detrimental effects on your numbers. Then again some people when it shows them their real power they arent "happy" with it either. Its not VDs fault though ... just their own for believing that air intake gives them +25hp cause it says it does on the box. :) You wouldnt believe how many times people tell me Virtual Dyno is wrong in a day. Then they go test it themselves against a dyno (as if a hundred people havent done that already) and then they come back and tell me its accurate. It gives me a laugh everytime someone is going to "test it" because Ive been down that road a hundred times with a hundred other people. :)
oh ok cool! what all do you need?
Here is what makes up a car definition. Let me know if you have any questions. Just send me the info back with your info filled in on a stock car and Ill be glad to add it.
<CarMake>Chevrolet</CarMake>
<CarModel>Camaro</CarModel>
<CarSubModel>SS</CarSubModel>
<StartYear>2010</StartYear>
<EndYear>2011</EndYear>
<Weight>3913</Weight>
<TransTypeManual>false</TransTypeManual>
<TransGear2>2.36</TransGear2>
<TransGear3>1.53</TransGear3>
<TransGear4>1.15</TransGear4>
<TransGear5>0.85</TransGear5>
<FinalGearRatio>3.27</FinalGearRatio>
<DragCoefficient>0.35</DragCoefficient>
<FrontalArea>25.3</FrontalArea>
<TireDiameter>27.79</TireDiameter>
<CarModel>Cobalt</CarModel>
<CarSubModel>SS Supercharged</CarSubModel>
<StartYear>2005</StartYear>
<EndYear>2007</EndYear>
<Weight>2,925</Weight>
<TransTypeManual>true</TransTypeManual>
<TransGear2>1.76</TransGear2>
<TransGear3>1.18</TransGear3>
<TransGear4>0.89</TransGear4>
<TransGear5>0.70</TransGear5>
<FinalGearRatio>4.05</FinalGearRatio>
<DragCoefficient>0.324</DragCoefficient>
<FrontalArea>22.02</FrontalArea>
<TireDiameter>25.6</TireDiameter>
I am an Evo guy ... what the heck is an LNF cobalt? If its not in the list in virtual dyno its not supported. If you want it supported read post #257
