Was this issue resolved?
When I apply a custom operating system, after I save and reopen the file the operating system box is blank, not sure if this is intentional or a bug with 3.4?
I have version 3.4.40, which I downloaded today.
PCM is from a 2002 Camaro, operating system 1253002
this is normal, after changing custo OS all other are blanked out
best reagrds
I have 2 bar tune .how do I get psi kpa to read correctly .i added new channel 2bar
Read correctly in tune or log? Post screenshot, log, tune.. something.
Can we get the A6 transmission torque based pressure adapt and volume adapt values added to the scanner? This would really help with calibrating these.
I may have missed it, but have we got support for our Non-linear Wide bands yet? I have an AEM 2300 series that i really don't want to give up. Was trying to set it up in my scanner tonight and looks like nothing has changed.
The axis editor will use the units that the axis in your table is using. Change the underlying table axis units, and the axis editor will use those changed units.
I'm not sure what you mean "impossible to compare inverse tables". Can you elaborate a little more? Pictures would help as well.
Attachment 65626
Will do. "inverse table" may be the wrong way to describe it, I believe I should have used axis instead.
On a Dodge, when I change injector data or manipulating fueling I change the InjPW vs Fuel Mass table and the Fuel Mass vs. InjPW table.
After making changes to the injector pulse width in the InjPW vs Fuel Mass table, I would open up the Fuel Mass vs. InjPW table, click on the InjPW axis and paste my changes from the first table then compare them (like in the pic).
Before 3.4, the InjPW axis data would display in a column which made it very easy to compare it to the other table. In 3.4 the axis is displayed in one row with the graph.
I hope this explains it a little better.
You can still do this.
Copy the axis, paste it in... copy the other axis, paste that in..
Ok. So you want to be able to view it in a single column, instead of a single row. Is that correct?
Wasn't sure if you knew about it or not Keith, but apparently the Desired Throttle Map and Desired Throttle Airflow pids aren't working in the scanner anymore...
Is there any update on being able to change the units in the axis on the torque model editor :) I know y'all have a lot going on, so won't bug you anymore about anything else right now...
Thank You
OK, so I was trying to add a second 30-0333 wideband into my scanner today... No matter what it will not recognize the second wideband as being hooked in... The second OBD controller tab will not pop up even after repolling... Something else - channels are hit and miss - may work, then repoll and lose 80% of them? Don't think I'm doing anything wrong, but who knows? Anyone else having issues?
Probably a stupid question but I assume you updated the settings on the wideband for it to be WB EQ Ratio 2 and not another one on 1?
Why of course not :) I was going by AEM's youtube instructions for setting up a dual setup - never mentioned anything about having to change the settings on the wideband itself... Guess that's what I get ;) Don't have the directions handy, but assume this is pretty simple? Minor setting change? Still having other scanner issues, but perhaps I've just got too many channels?
This would explain why both work individually...
Thanks Carson
