How do I add some WOT timing? 05 LS2
This is usually your WOT Area. You can open the scanner and put the pedal to the metal and read your RPM and cyclinder airmass.Quote:
Originally Posted by TrekGTO
Don't forget to smooth the edges.
http://www.hptuners.com/forum/attach...1&d=1167965795
another way is to open up your 1st histogram with the timing tables... WOT is usually in the bottom right area.
Another way is to add PE/COT fuel at the appropriate Commanded AFR.
That way if you get to that particular cell somehow other than in PE you won't have too much spark advance.
Not sure why some cals have it zeroed but they do...
What? :shrug:Quote:
Originally Posted by EC_Tune
Table is Spark Correction AFR Correction and the table you are interested in is the Gas table. It has adders/subtractors for PE fueling.
