Like the title says trans is slow going into R/D but only when it's cold. After it heats up fully it acts normal. TCM is unlocked but I'm not sure if it's tune related. Any thoughts on what could be causing the issue?
Noticed my '15 Yukon Denali does that. It's almost as if the fluid flows way too slow, with insufficient fluid pressure. I've just got in the habit of using remote start to get things flowing, before I hop in & go.
I got it fixed. Just used the fast learn function in hp tuners problem solved. No more clunking in to gear and smoother shifts.
