1 Attachment(s)
issue with tune op jumps in and out
Attachment 97266
Can some one take a look at this log and see what they think could cause this issue I have never dealt with any issue like this. Truck is 6.0 stage 4 truck cam snake eater 850cc injectors. 4.10 gears and 4l80e with 3000 stall and jakes stage 2 performance kit installed. I can not figure this one out I have tried pulling all tq management still same issue and it happens pretty random at a steady throttle position. Logged a ruff air flow table idles good and issue is not there at idle went to go log some data for ve and issue accrued. I was trying to isolate the issue so tried different speeds dose it in second gear as well just gets more violent. know if you power brake and hold throttle steady issue dose not happen. I haven't touched pe enrichment so that is still stock so wont come in till 90% throttle
