1 Attachment(s)
Izze Brake Temp Sensor
I made an enhanced display object to display that data from some Izze Racing brake temp sensors (sensors). Here is a video I made using this template.
https://www.youtube.com/watch?v=BzwmTGU2asI
This object is a bit more involved than simply adding it and selecting a data point. You have to open the Script Editor and then go to the background script view. There you'll see where to define the names of each channel for the sensor. Once you have that done you should be all set. If there's a better way to accomplish that that would be nice.
That`s really very good ! Fantastic information. I don`t think the numbers are necessary in use, the colours changing is enough but I really like that.
The numbers are easy enough to remove if you so desire.
