why is there no ability to export tables and save them and then import tables from other tunes in the dodge tuning? mine are greyed out and i cannot select them. is there a setting I am missing?
Ever figure this out? Mine is doing the same thing trying to tune GM
Greyed out should only occur when you are comparing tune files and the compare tune just simply doesn't have the same table or it is labeled differently by HP Tuners. If you truly believe they are the same table and just not comparing right, open your tune and compare tune in two completely different instances of VCM Editor and just do a copy paste or typing in the values you want. No, you cannot import changes if VCM scanner is not recognizing them as the same tables.
