In/Out stereo plugs
Okay, I'll post this here since I can't get an answer on Innovate forum. The in & out analog cables with the female 2.5 stereo jacks - the terminator plug goes in the IN cable, what goes in the OUT? Don't tell me it's the $12 innovate cable used to hook up to laptop that DID NOT come with LC-1? Is that the only way to hook up laptop and be able to program the LC-1? I don't want to start tuning this thing if I haven't got it setup in the controller properly yet.
Yes, you should have gotten a serial cable that plugs into the other phono plug. That's the only way to program it. You will want to wait to make sure its setup correct before you waste time collecting data.
^^^^ ditto... and as stated... the serial adapter does come w/the LC1... check your packaging again, if nothing then contact Innovate...
Gentlemen, thanks for the reply. I'll check box when I get home. That sure is a relief:cheers:
