Originally Posted by
5FDP
Are you setting the MAF fail high to 0hz and the 3 MAF dtc's to fail on first error when speed density tuning?
Overall is just looks like you only hit it with 20% and do no real data logging to tune it in. If using a wideband and an AFR error it should be pretty straight forward for making the changes. Then you can put in in MAF only and start tuning the MAF curve the same way with an AFR error.
The stock fuel pump might be enought for sure those small 24lb/hr injectors are not big enough for a 370 cubic inch motor. You'll max those out on your first WOT pull.
