2 Attachment(s)
Maf placement and tube size.......
I have been running my car MAF only for a long time, and it has run great like that. I was running a 3 1/2 inch pipe with the maf in a pretty standard spot ( see pic below) and all was good. For reasons that are not important, I had to make a new IC to TB pipe. I decided to go from 3 1/2 to 4 inch and to move the maf to a different spot, (picture below) thinking maybe it would be smoother than it was before.
The new design is basically not tunable to my satisfaction. The car runs great, but has a small hesitation (lean spot) off idle and light surging at cruise.
I tuned the VE to perfection and when in VE only, the issues are not there. I would consider going SD except I have never found a clear answer on the relation of maf and/or VE to torque reporting. My car is a 6L80 and I don't want to take a chance of a change to SD screwing with the trans.
The real question I have is..... would the issue be due more from the different maf placement, the larger pipe, or a combination of both. I can change one, or both back to what they were before if needed, but would like to know which is really the culprit.
Thanks....
New setup....
Attachment 53265
Old setup....
Attachment 53266
