3 Attachment(s)
Feels like I am trying to hit a moving target. Logging VE error
I installed a new came 224/230 595/595 112 LSA. I added 2 grams to base running airflow and used a VE table that seems to be more in line them my old one.
When logging percent of error at cruise speeds my numbers jump a lot. Example. 1600rpm table about 45-60 kPa area cruise, light throttle getting .96, .95. Under a little more throttle like a slight incline those cells hit 1.0, .99. I've been using the average and multiply by half but it seems like it won't settle. I don't remember is being like this when I tuned VE and MAF for my old cam 204/218 550/550 (04 z06 cam)
The came is a lot different then the old one, could that be my issue. It's also hard to keep my IAT's down unless moving.
Motor is a 370 lq9, L92 heads with LS3 intake, DBW and LS3 injectors. I am running an AFM1600L with a new sensor. Exhaust is dual 3" with x-pipe and dual 3" black widow mufflers.
If you have a moment, take a look and give your thoughts and opinion. I am thinking of going back to my last known VE tuning file and starting over.
Attachment 51878 Attachment 51879 Attachment 51880 tune, config and log to the left
