3 Attachment(s)
High Ve values- turbo car
Hey guys, just fired up my first turbo build. Right off the bat, I am having to input what seems like really high ve values (70+ in idle regions) to get this things Lambda error in check. The ve values in the lower map region are much higher than stock, which is odd, because this is a stock engine despite the turbo. Is this normal to have such high ve values?
A quick run down on the setup..
81 buick regal
stock 01 5.3
4l80e
2005 p59 ecm running DBC and flex fuel
converted to 3 bar
ZR1 map sensor
ID1000 injectors at 58 psi base
Boost referenced FPR
pt7675 turbo
