Can I shut off the personel anti theft on a 2112 f150 with a 5.0. I bought a motor trans combo with wiring and didn't get the ignition switch.
I doubt there will be a 2112 F150 in the future lol.
I know there is a switch for the 5.0 mustangs to turn pats off and on.
Fast5oh, can you verify again that the PATS is able to be disabled on the 5.0's for mustangs. I have one sitting here at the shop that I can't fire up until the PATS disable is live.
I don't have a way to test it out today. But the switch is there to disable it. Maybe eric knows if it works or not.
The PATS disable switch is there, but it alone does not disable PATS. There is a procedure that goes along with that switch that will need to be done via the scanner. I am working on it. No ETA
To be clear though, the ford pcms will run in a kit car with just the pcm, ignition switch and key from the matching car. And they dont freak out missing other computer modules like some of the GM cars.
You don't need all the modules, they don't freak like GMs. You can either run the Ford Racing Control Pack (which can be tuned with our software), or you have to swap in the PCM, ignition switch, and whatever the key talks to, may be part of the cluster. I haven't looked that far into it.
Eric,
Is it possible to write the control pack strategy to a production car PCM, or is the hardware different?
David
I have never done it, but I don't see any reason that you can't. I believe you could actually low level flash the PCM with IDS, and convert it fully to a control pack firmware. The hardware engineering numbers should be close to the same, if not exact.
I would stick it out with the 2012 ECU, then PATS disabling is on the list.
-Matt
I ran across a thread where a guy flashed his control pack to a 2013 with a IDS to write a VIN, then immediately re-flashed the crate strategy back on with SCT and it worked for him. Although that's a different direction.
David
Hey Matt, I suppose I wasn't very clear in my reply. What I was trying to get across is that someone was able to flash from a control pack strategy to a 2013 GT, and back... So maybe one could write a control pack strategy to a production car PCM, if they were doing a engine swap to get around PATS. In that case there shouldn't be a VIN issue.
Does anyone have a solution to this as of now?
I will be needing a solution as I'm using an F150/6R80 setup from a junkyard pullout in my street rod setup. I plan on going factory ECU/Harness and reworking the harness, and hoping there is a solution before I get finished so I'm not stuck waiting.
Is there any other solution in the interim that I could use? Is it possible to flash the FRPP computer with my stock F150 tune and get past it if I buy the FRPP kit and ditch the harness, or is it truly a software only issue not hardware? Looking for any alternative until HPT supports this, so I'm not dead in the water waiting.
Thanks!
