injector bank select table
just wondering: is there any other affect to getting the bank assignment table correct? or is it just LTFT and STFTs? im running a low res crank reluctor and single coil/dizzy.
the reason I ask is because I took my impala to the dyno with the wrong injectors wired up (18436572, instead of the LS1 order) and got 220rwkw with a sketchy as hell AFR and wideband readings all over the place.
after a rewire to the LS1 injector firing order and a revisit to the tuner I got the same power pretty much exactly, but a much nicer and smoother AFR. BUT I had forgotten to change the bank assignment, and was wondering if this would any sort of affect on WOT power?
yeah that's it really. cheers.
