1 Attachment(s)
IAT timing
First of all, is there a parameter in the scanner that monitors how much timing is being pulled due to IATs? I only see IAT advance and not sure if that's the right one.
Also, am I doing this right in terms of IAT pulling? I zeroed out the 2 multiplier tables and just use the base table to pull certain amount of timing.
But the other day I went out and tested this theory and was at 113* (should be pulling timing by then) but saw full timing even at high load. Thankfully I didn't have any knock but also didn't see any timing pulled. I'm starting to think that 1 of the 2 multiplier tables actually multiplies the base table and since I zeroed it out it's all being multiplied by 0 and thus there's no timing pulled ever?
Attached is the tune
Set them both to 1's. This says use the IAT table 100% as stated. Any number less than that is a proportionally use of the IAT advance values (i.e .5 would use half the value). Zero says don't use at all.
Ed M
