Originally Posted by
gn2beatu
I have been hearing about several people having this issue lately and 2 out of 3 times it was the sprocket causing the problem. On two the clearance space was not correct between the cam and the sensor, and a differnt (brand?) cam sprocket fixed it. The third persons issue was with the wiring adapter that came with the LS2 cover. I just put a 24x 5.3 with LS9 cam in my TBSS before I sold it, and didnt have the issue. Does yours use that little adapter clipped to the cover? If so are the contacts clean and not bent?
Im sorry I dont think the scanner can do that, I think your goona need a Tech 2? Someone ellse will correct me if Im wrong.
