Does everyone else's shift speed vs tps vs shift table under 'performance' show all zeros in the 1-2 shift and 2-1 shift rows?
Mine does and I'm wondering if this is normal...
No and that's definitely not good. Those are the mph that your trans will shift in given a certain throttle position value. I don't know how it even shifts with all 0s.
Maybe it never goes into performance mode? The values in the 'normal' and 'hot' tables are there... ??? ???
Not sure what car you have, but Performance shift is turned on by pushing a button. The GTP's and I think the SSEi Bonnievilles have this.
If you car did not have performance shift, then I have seen some CAL files with all zeros there.
You can email me your year, model, and make, I can look up the wiring and tell you what pin it is on C1 or C2 that will have the wire for performance shift.
Loyde
http://www.fastfieros.com
Quote:
Originally Posted by PiLOTLiTE
Oh, I didn't see the performance part. Just make sure all the tables are identical. Copy one over there. I though you were talking about the normal table. Yes, we're not supposed to be in the performance table, but just fill in the values.
