Need a 'really high' idle setting...A/C switch?...
2000 Camaro LS1 ECM. The harness is cut down to run stand alone in a buggy. Running SDOL.
I'll be brief: I race a single seat offroad race truck. When I have to get out and winch I'm all by myself. I'd like to have a 'High Idle' button so that I can keep the alternator rpm up when I'm out of the car winching as I'm not able to press the gas.
I'm thinking I could accomplish this with the A/C switch. No?
First thought is 12 volt to the A/C Status (Red plug, Pin 18, DkGrn) and set the A/C on idle to 2k rpm or so. That sound right? Does the IAC have enough adjustment to make that happen?
Or do you see a better way to accomplish this? (No throttle adjuster cables, I've got enough crap in the car as it is.)
Thanks.
