Idle tuning w/ quick blip of throttle in park
Hey guys! Been a while since I have done some idle tuning. I have the idle pretty good (IAC's could come down a little further but its ok for now i think).
I forget what the proper procedure is for the ls1 (2000 pcm) for fixing quick throttle blips. I thought it was the throttle follower tables. There have been too many hands on this table in the past so it is most likely the issue.
What values should I be watching and how to adjust based on the values in the appropriate tables?
I think IAC, MAP, and Advance at first but maybe there is a better set of data I should be using.
I attached the bin, scan log and config.
Thanks in advance all!
