Hi
i´m gona try to help one guy out
he´s swapping a ls1 to a S10 truck 1993 model and it doen´t start up :)
what exactly do i need to do to dial it in /pair them together and have it start up.
thanks
Baezi
Hi
thanks
Baezi
Post the tune you are using ...
The VATS needs to be disabled for starters. If you can post a file that would help.
I'd guess the issue is wiring related.
yea i think so too think the wiring is wrong to fuel pump
ok i turned VATS off
and the car just started , no fuel and no spark
we went over wires and we found out that he forgotte to fasten 2 grounds near the ignition back off the driversside head , we fixed that
started the car , the ignition came in but still no fuel, i commanded fuel pump "on" in the scanner and i heard a click in relay but the fuel pump was still off. No fuel to rails
So would you say that it´s wiring related or am i missing something in the tune maby
thanks
Baezi
No fuel pump no fire. Fix or hotwire the pump and it should start
I agree. If you're commanding the pump to turn on and you hear the relay click inside the glove box, at least now you can focus on the pump. Hotwire the pump, check it's grounds and such. Get the pump to whine and fire the engine over so you can narrow down the pump's issue.
