Hi,
did somebody dry to read the pcm on a Ford Mustang V6 4.0L Year 2006
I dry it but it doesent read it all.
Hi,
I did. It will inform you to submit it (the read file) to support and they will send you a beta that will enable you to tune it. I did the same yr/model as you, 06 stang v6.
Same for me, but I cannot connect the scanner (even with the beta version) it say : can't create log ....
Means you are using version 2.23.146 or 2.23.147 which had a bug that was fixed later that day.
Not sure why you are posting this on our forum. You should simply contact support and we would tell you to update to the beta that was posted on your customer page for the last week that has the fix.
yes that's what I did. I received the 2.23.150 beta version of the scanner and it's works perfectly !! thanks HPT support !
