http://www.trifectaperformance.com/files/frp.jpg
:confused:
Well then ... That doesn't look like HPtuners tables ?? Can you just do a search in the O/S file for these numbers and then find it that way to add them?
:confused:
Vince is the man, hptuners needs to hire him.
Guys don't post links to competing products here as I don't want to have to delete the thread. If you want to request the table I have no problem with that and have already forwarded the link to the thread on cobaltss.net to our head engineer for further review but don't turn this into an hpt bashing thread as there really is no call for that and it will not be tolerated here.
I didn't see any bashing or threatening statements. Just a simple request to add fuel tables
how long do you think until we get these tables bill?
Weird, my 07 msut be programmed different then that particular car. I have logged high rpm using my dashturkey and have never seen DI pressure fall off from 2146psi.
I'm sure theres some interpolation going on between cells, but who knows.
Sorry Bill , Didn't mean to insult anyone over at HPT I was just trying to get you some information that might help your engineers, Using that alternative open source software and the values in the tables I thought might help you search the Hex code for these numbers , I should have saved the pic and used an alternative upload source , That is my fault. I know how busy you guys are with stuff and you guys don't have time to surf all the LNF platform fourms so I just thought I would cross-link the info not for competing purposes as most of us already own HPT-Pro. Just thought it could be some useful info. :cheers:
Yeah your post was fine, however several people not only used profanity but links were also posted directly to other tuning software sites which is NOT tolerable.
We are all grown ups here I just want us all to act like it and use a little tact when posting.
We need the fuel tables unlocked bad.:D
Mine was deleted too, I said nothing negative.
Anyone can go into EcuFlash and make their own definition and get it to work. You will need the hex addresses for every table and then test them to see if you have it right etc.. Takes an insane amount of time if you dont know what you're looking for. Ill be waiting for HPT to release the newest beta lol...
Can you read the calibration with ECU flash?
Why would you bump this thread to ask that question?
Basically, unless you are a software engineer, don't bother.
thanks for the update Bill.
I dont need the tables RIGHT NOW....since my customized HPT tune is perfect right now with the amount of power/boost (28psi) I'm making.
But I'll be upgrading my valves/retainers/pistons/rods probably mid summer........and will be boosting higher and hoping to get more power from this LNF engine.
Hopefully, by the time I finish my engine rebuild (which is months from now), we have this table ready *crossing fingers*
Again thanks! :)
Any Ideas when we will be up to bat again Bill?
I almost have my GXP back together with a VERY big turbo aboard.
