Please take a look at my tune.
Ok, I do not know if I have all the correct peramiters changed for my conversion to 408, but I must say the car is now driving pretty good. Please take a look at my tune and my WOT scan. I am running SD, and I realy have no idea how to tackle the new multiplier tables next to my primary VE table. I think this is were I need to work to correct my AFR threw out 1st gear, right after I go WOT. I realy need some clearification on how this table works and effects the VE. I also have this large loss of timing right at the start of WOT that I am not sure what is causing it or what to do to fix it. If you look at the run while in 2nd gear you will see it is a little lean, but while in third gear it goes way rich, this seam strange to me and I have no idea why it would change like that as compared to each other.
Those are just what I see wrong at this time. I am hopeing some one will look this over and help me fine tune this the rest of the way in. I believe there is still alot of power left on the table here. I was expecting to make between 580 to 600 crankshaft hp with this combo, and I do not think I am close to that yet.
Thanks guys.
