PE Mode vs MAP
I noticed that the Stock tune for my car has a PE enable MAP setting of 15 and MAP hysteresis of 6 (meaning that it goes out of PE mode at 9). Problem is, I noticed that even at WOT, my map readings are ranging from 14.21 to 14.36. I would take this to mean that I'm never going into PE mode. I also have ltft's of around 8.6 at WOT. I need to richen things up at WOT and I'm Thinking of first moving the MAP setting to 14 to ensure I'm in PE mode. Then adjusting ltft's through the IFR table. Is this a good idea or not? ???
Re: PE Mode vs MAP
The PE enable map is in kpa, not psi like you are logging. It is going into pe whenever their is an increase of map by 15 kpa. As far as your ltft's, reduce your ifr table until they go slightly negative.
Re: PE Mode vs MAP
Thanks. That clears things up. I'll leave the PE table alone for now. I read at http://ls1edit.slowcar.net/tuning.html that the other way to reduce ltfts was to remap the MAF table. My ltft's were around +8, so I scaled the MAF table by 10% and pulled the #16 and #23 fuses to reset ltft's. I haven't relogged yet. Any idea as to what are the pro's and con's of using this method as opposed to the ifr table?
Re: PE Mode vs MAP
You can reset your ltft's via the scanner without pulling fuses.
Re: PE Mode vs MAP
That's a great feature. Thanks. I'm still learning this software. So far, it's been great.
Re: PE Mode vs MAP
The negative of this is that it affects your timing, but with hptuner you can adjust it however you want anyways. The reason it affects timing is because you are in effect, telling the pcm that there is more air coming in, so it pulls some timing. It also affects shift firmness I think in autos.
