How stable is a OLSD tune?
I have the VE tuned, and it does fluctuate some, I assume due to temp and humidity, it will be lean one day and back rich the next, so I have a good medium...on more than off...I have two questions, this is not a track car, does the WOT part of the tune need to be closer (as I am sure it will flucuate also) than the 4000 rpm and lower?, (how close do you need to be to be safe?) and wonce you are satisified do you have to keep the WB hooked up or can you remove it, as I would like to remove it if I can.
thanks in advance
