Originally Posted by
redhat
Working through thoughts on a swap idea. Would like to use a DOD-deleted cammed L83 Gen V 5.3 and a 4L65/70e.
I see on some GM sites they offer a crate option with an LT1 and a 4L70e... under their connect and cruise lines. Engine control system is 19368831 and the trans control system is 19302405. The 19302405 is a SuperMatic Transmission Controller... is this essentially a T43 TCM? In instructions, it says to read the ECM/TCM, select a 2008 Savana or Express 1500.
I am figuring to run a Gen V DI engine, you'd want an E92. I am curious on what factory ECM/TCMs I could/should/would want to pull and use together to accomplish this.
Does anyone have a base calibration from a Connect and Cruise/ERod setup?
