Originally Posted by
edcmat-l1
Need to check the header tube temps on bank 1. I bet that motor is running on 4 cylinders. Trims are +50% and the B1 O2 is in the dirt. I bet that whole bank the header tubes are cool to the touch. If that bank isn't totally dead it has a horrific vacuum leak or leaks on that side like the intake o-ring seals are completely missing, or the injectors don't fit right in their bores in the intake. Seen that many times. There are 3 different o-rings sizes that I know of.
Tune file is atrocious. I'd recommend you pay someone to do it for you. No offense. Those aren't the "normal steps" to figuring out the idle.
And yeah something is screwy with the baro. Unless you're in Colorado.
