1 Attachment(s)
Maf Sensor Intermittent Failure?
Ive been slowly making changes to this project. Setup is a 5.3, turbo cam, 7875 turbo, pump gas, p01 ecu, 4l80e, dbw throttle in a 1970 c10. Im suddenly having a issue causing the truck to not start. Looking at the check engine codes shows that the MAF sensor is not failing. Im not sure what would be causing the issue since i havent changed anything MAF related, it has all been ironing out the VE table. Could i get some guidance and get someone to take a gander at my tune file to see if there is something i am overlooking. Im guessing its not starting becuase the MAF is not failing but i could be wrong. I say that because everytime i would look for check engine codes the MAF codes would be there and since it has not been starting the MAF codes arent showing up.
Attachment 141905
