2 Attachment(s)
LFX E39 tip-in KR? It's not burst knock
Hi folks!
I swapped an LFX into my Exocet and have finally gotten around to tuning it. I've tuned my MAF and VVE and everything seems to run very well. However, there are two issues I'm having (with two corresponding threads in this forum) that I'm hoping someone might be able to help me fix. Here's the knock issue.
I seem to be experiencing knock on tip-in. I disabled burst knock to see if that was the cause, but the knock persisted. I can remove all the spark advance in the world, and I'm still reading knock on tip-in. There is no cylinder consistency - it appears in various cylinders depending on the event. The engine is mounted on stiff poly bushings, and I can't seem to find anything loose that would be triggering the knock sensors. Wideband EQ ratio looks good and narrowband O2 sensors don't seem to indicate a lean condition.
Attached is a tune and a log. Does any kind and wise soul out there have any ideas about this issue? Attachment 141579Attachment 141580
