MPVI1 Ecu idenfication
hello, i am new to using an mpvi1 and when you go to read a vehicle, most of the times it just brings up a drop down menu with all the ecu's listed on it and you have to select which ecu you have, then it will go ahead and read. Is there a way i can use to tell which ecu i have? Im having trouble identifying the ecu im hooked up to. I never realized there was so many until i saw that list haha, Thanks in advance guys
If it doesn't auto recognize it you would need to find a way to determine what ecm it has, either by service sticker, knowledge of the platform, etc.
thats what im having trouble with. For example, the Chrysler 300's. I have one were working on thats an 06 i believe, most of those have the NGC4, for some reason this one has an NGC3. The only way i know this is because i took a read with the newer mpvi3 and it auto identified it. Maybe ill just have to do that from now on. Was hoping there was a source or software i could turn to or buy that would help. Thanks
if its not auto recognizing theres typically a reason
a. custom operating system
b. ecm corruption
c. not a supported application
d. os and vin information not in our database
