E38 ECM OPERATING SYSTEM FLASH QUESTIONS different operating systems
I have looked on here for couple hours and cant seem to find a answer to a question i have and really wanna know for the problem im having now and for future purposes.
so i have a 2010 sierra that i fried the ecm to, long story, but its toast . so i called around to the local yards and only 1 had a ecm for it. and so when i hooked it up to load in
the original file from the sierra ( thank god i do have it ) . but when i read the ecm from the yard it says its from a 2007 pontiac g6 with a 3.5.... which the operating systems are
different.
So , i am just trying to make sure i can write entire over the 2007 g6 file and it will work???????
or is that not the right way ?
and so now im also wondering if this will work like this is this also possible for p01 and p59 ecms?
so if they have different operating systems will it WORK if you just write entire over it if your just pretty much loading it for complete different vehicle anyways?
and if not do only some work with others?
and if so how do you know what ones will?
yard swears up and down it will work just needs programmed....
just wanna check with you guys.....
thanks in advance
