Originally Posted by
smokeshow
From a cold start it doesn't matter... The engine is at ambient temp, just like the injectors. But on a hot restart after flash, the controller initializes the injector tip temp to engine temp, which is obviously an overestimate. So the model has to stabilize first, which isn't something you can monitor. As we mentioned, data immediately after a flash is unreliable and should be discarded...but if you'd like to get rid of the richness after the flash anyway, set that injector temp offset table to 1 across the board. Just set it back when you're done with the rest of the calibration so if your injectors ever do get that hot, you don't have an engine that refuses to start.
