new to hp tuners, need help getting the truck to start and idle for the first time so i can see if there is no leaks before taking it to a tuner
7068 t4 t70 turbo
80lbs smartfire injectors
Attachment 127273
i would really appreciate the help
7068 t4 t70 turbo
Attachment 127273
2008 gmc sierra 4.8
sparkplugs br7ef gapped to .024
Did the injectors come with data?
I've never heard of smartfire injectors, they sound cheap to me.
Maybe someone here can do all the changes to make it run in speed density because it would be too long to type it all out. Don't forget to list the map sensor you are running for boost.
they did gave me injector data Attachment 127526Attachment 127527
just that e38 injector rating maxing out at 64lbs
i would really appreciate the help,
Just double the stoich table and enter half of the injector flow value.
okay i will try that, also it seems like my map is not setting to 2bar it table goes up to 175kpa and not 210kpa
