Sprinto7 are you out there
Have you ever had to relearn your crank sensor. I remember you had your 1.4 in a race car.
I am having one hell of a time trying to get mine to relearn. The first time I go thru the procedure it says relearn failed then when I do it again it says must be in park or neutral with engine running. It will continue to do this till I disconnect the battery for 15 to 20min. Then it goes back to the same thing relearn failed then park or neutral with engine running. Do you have any ideas? If I can't get this corrected I will drive it the way it is. I started this relearn because it has to warm up to 140*f before it will run right. Once hot it runs fine except for little adjustments I want to do.
I have the 1.4t and the 6t45 trans out of a 2012 cruze. in an off road buggy
No BCM but the can bus is a complete circuit, I do have an obd.
