in the scna below if you the MAP is not reading right...... (in the graph display for it to read right you have change it the MAP "PID" not sensor,
but even tho it is right in the table display the histgrams do not that reading what is going here?
You probably have that VAC/Boost pid setup as the MAP sensor so when the scanner goes to calculate the sensor it takes (VAC/Boost pid+MAP(SAE))/2=map sensor
how should i set it up?Quote:
Originally Posted by Bill@HPTuners
Don't apply that VAC/Boost pid as a sensor. Just leave that section blank
wont let me leave it blankQuote:
and the list of voltage is all fucked up if i click on my wb or the boost it list all of them???
okay got it but in the linear are there are like a crap ton of listings in there ? why? and how do i know what one is being used? some are the old ones from old senors i had
