2 Attachment(s)
Cant get a steady/stable idle from off idle to approx 1700 rpm, Gen 4 LS3 E38
Just like the thread says. Cant get the engine to rev up a bit and hold steady rpm below 1700 RPM.
I am just working out the last of the bugs in the car. It has done this from day one since I installed the TSP Stage 2 camshaft.
I can see the Throttle Control source changed from "Idle" to "Pedal" mode when pressing on the accelerator pedal.
The issue is here that with a very light press of the pedal to get this thing to rev up a few hundred RPM, it does not switch into Pedal mode, but rather stays in idle mode until roughly 1700 RPM. I have included a log but you can clearly see the adaptive idle is pulling spark to drop the idle even though I am actually on the pedal a few percent.
When you watch "Idle Mode" it changes from "Speed Control" to "Follower" at the same time as Throttle Control source changes from idle to pedal mode.
Is there any way to adjust this or any settings I can play with to make the PCM activate pedal mode if it has any kind of throttle input?
The engine idles and drives perfectly . Even when driving at a very low RPM it does not do this.
Idle only.
Check out my log. I've also logged all the Throttle percentage voltages and percentage's.
Attachment 144415
Attachment 144416
