I'm going to be changing gears in a park ave from 2.93 gears to 3.69. I know how to make the change when going from 2.93 to 3.29 by entering 3.69 with stock tire size and hit commit. But what do I enter to go from 2.93 to 3.69?
Thanks.
Thanks.
4.13649
Russ Kemp
Cool, thanks, I was figuring it was somewhere around 4.10 So just enter that with stock tire size and done right?
Is there an actual way to calculate this or is it written down somewhere?
I realize this is an OLD thread, but I would like to know the answer to intimidators question... It would be helpful. Thanks!
If your asking about tire size? It can be calculated perfectly by airing up tires to your normal air pressure and then with tires warmed (driven on for 10 minutes or more, place a mark where your front tire and the road meets on both tire and road then roll car forward until the mark on the tire comes in the same position again, then mark road. Then simply measure the distance between the 2 marks on the road and that is your tire size as driven!
3.69/3.29=(1.12158)*3.69=4.13
I didn't know you had to do this. Thanks for the info, I'll be doing a similar swap on my Lesabre.
