Could someone look at my tune and see what might be wrong. My PE is not coming in until after 4000rpm even though my PE delay is set at 5rpm.
You hot/cold pedal enable is 90%, you didn't get above 90% most of the time you where in the gas, so it was waiting for you to reach over that mark to enable it.
You'll also want to smooth out your VE and MAF curve, they are still a little choppy when you look at the 3D graph and airflow curve. It's causing your fueling to jump around alot.
Try these settings...the TPS is not the normal TPS%, it is Throttle opening effective area percent without the idle contribution. So the 12 will yield about a TPS% of 42 and the 8 is about 35%.
Ed M
Attachment 62077
Thanks guys. I knew there was something that I missed. This is my first ground up tune so I have expected some issues. 5FDP I was wandering about how my VE table looked in 3D. I'll sooth it then I go back to my MAF cal. It has been frustrating when trying to cal the MAF with the numbers jumping around a lot. Should I smooth just the effective area that I have been using or should I include the area higher in the rpm curve since it seems that I have such a high peak in the middle of the 3D graph? Thanks again for the help.
EDIT: Ahh, I see OP has an ETC? and then it's area, but on mine with cable is still really % right??? (hope so).
-D
Whoa! Mowton - is that so?? I <assumed> (never assume, sigh) it was TPS % in those tables because thats what the help text appears to say, but I did notice "anomalous results" as they say, when I set mine, and assumed (again!) that it was just me.
Grrr, bitten by another oddity, have to go change the values again then.. :)
-D
I have to say, I didn't realize I was answering a Gen III question...sorry. I know the E38/67 throttle enables are effective area-idle contribution but have to be honest and say I don't remember that being true for Gen III setups...sorry. I am not sure but believe in this generation that it did represent the TPS%....
Again apologize for the most likely misinformation. Test on your setup. The higher MAP setting is still what you want and you want a throttle enable that is out of play early.
Ed M
So let me make sure I understand. I should set my TPS% for Hot/Cold to 42% and 35% in the sells you had 12 and 8. The Kpa limit should be reset from 55kPa to 85kPa. Any thoughts on my question about smoothing the VE table.
Set throttle that way and log to see if below the 85 kPa Map criteria. You want the Map to be the deciding criteria for entering PE, not the throttle. As far as smoothing VE, search Forum. Dave Steck (DSteck)provided us a MAF and VE smoother which I use all the time. You may have to massage the axis values but will can return the shape of your VE to a more reasonable surface and stabilize your error collection/updating.
Ed M
Thanks Ed. I tried looking for the MAF VE smoother info you mentioned by DSpeck but had no luck. I did so many searches the forum would not let me do anymore LOL
The MAF smoother was maybe this one?
kr D.
Thanks everyone. I searched HP tuners and tried many combinations of DSpeck, VE, VE smoothing and MAF but got locked out before trying MAF Smoother and I had not tried using Google. Thanks Ed and dermotw.
I went to that post but did not see links for the Excel sheets.
