2 Attachment(s)
Adding axis to VVE table map/baro for boost? And a PE question
So I have a question, when I bring up the stock VVEtable it only goes to .93, can I just add more axis to this to help with the new 3bar map and the airflow? Under any sort of boost, I max out the .93 region rather quickly. I'm wondering how you guys are going about filling in these regions safely? I noticed when I added a few axis tables say up to 1.21 for the 1.2bar map it made the cell numbers get way larger for only the bottom section of the VVE. I take it once the pcm runs out at .93 it just linears a value? Whats going on here?
Also I noticed on this pcm, it doesn't have a MAP setting for PE, so I cant set it to enrich at 100kpa as usual. How do I go about making it go PE just into boost? Its hard to find what throttle makes it go into boost as the map was a way easier way of allowing for PE. I don't see any BE tables either. How do we go about this?
Attachment 61898
Attachment 61899
I get a weird almost lean pop right into boost. But I have PE turned up to 4000 just trying to get the VVE dialed in under boost levels.
:banghead:
