Is there a setting or table I can adjust for throttle response?
Something like the Sprint Booster would do? $300 is waste to me if HP Tuners can do the same..:banghead:
Thanks.
AJ
Thanks.
AJ
YOu mean to tell me that nobody knows how to increase throttle response?
Reduce torque management.
Also set this table to all 100's
Russ Kemp
On an e40 ECM that has no TCM is having those center cells set to 100 going to matter? I don't' see how ti could. This is what my stock table looks like though:
http://www.patooyee.com/miscpics/etc.jpg
I have shitty response. It takes about a second for the DBW to do anything when you hit the pedal at idle. If you hold it slightly above idle it cracks like a whip.
