2 Attachment(s)
Open loop idle in gear only
Trans am ls and 4l80 segment swap from a 1999 Silverado. Wierd problem that I'm hoping has a simple solution. Problem is when you put the car in gear it triggers openloop "OL-Accel/Decel". Put it in neutral and instant closed loop. Also if you give it some throttle while in gear you get closed loop. It appears only to be while you in gear and foot off the throttle that it will trigger an open loop idle. Moved pe stuff around and its still happening so help me brainstorm on what could be the culprit. No bad ideas here cause Im about out. Thank you.
Attachment 69028Attachment 69029
