A/C compressor turning off at idle..
Hi guys, has anyone seen this problem before? Wots happening is, A/c is on and cooling fine (plenty of gas, tried over and under gassing unit) when idling in Park (650rpm) stays on even forcing down to 450rpm in Park...
As soon as it is placed in Drive (550rpm) the compressor cuts out. Even forcing the idle up to 690rpm in Drive does not bring the compressor back on, it will come on at about 720rpm.. Are there any adjustable tables or parameters that control the A/c besides the pressure sensor? as when logging the sensor, the compressor, in this situation doesn"t respond.
