Shift later as trans temps rise, how to fix this.
So ive been chasing a shift issue for a while now. the 2-3 shift is very inconsistent. But tonight while logging Ive noticed the transmission shifts fine while cold but as the temps start rising the shift occurs later and later until finally it will hit rev limiter.
I can post up some logs if you guys would like to see them. when the trans was around 130 degrees it was shifting about 400 rpm beyond commanded shift rpm which sounds about normal. But once it was up around 165 it wasnt shifting until about 700 rpm after set rpm.
I do expect some shift delay and the shift rpm is set at 5700 I believe.
Im thinking the pressure modifier table might help but It seems most people dont touch that.
