2016 Ford F150 With Aftermarket Cams
Hey guys I just put together a 2016 F150 with a set of cams that use the mustang firing order, I am now looking to figure out how to change the firing order as well as the injector firing order in the tune if that is possible? I have searched around a bit and seem to keep finding conflicting information on what needs to be done to make this work, some guys saying I need to re-pin the wiring to match that of the Mustang while other people are saying it can be done in the tune however none of them seem to have actually done the work. Any help with this would be greatly appreciated.
The Truck itself is a 2016 F150 5.0 with a Roush stage 2 supercharged setup, it's pulleyed for around 14-16psi, Manley rods and Pistons 9.5:1, and has a set of fairly mild blower cams .516/.514 227/233 @.050 123* LSA, 72lb injectors, its converted to a return style fuel system that overkill with 2 Walbro 450's in the tank, and is backed by a 6R80 with a Circle D converter, TCS billet intermediate, Exedy clutches, and a few other small bits that our trans builder recommended.
