Is it possible to flash a m6 02 C5 zo6 file into a 2000 C5 m6 so I can have the single VE like the 02 file vs. the primary and secondary ve tables in the 2000? Obviously so long as I have both years on my cable.
yeah but the vin wont be correct...your better off getting a custom OS for it so you can keep the bin & loose the secondary ve.
Not too concerned with the vin just want to make sure it can be flashed over.
Quote:
Originally Posted by foff667
yeah i cant see why you couldnt.
Why not just use the 1-bar SD enhanced. Solves the problem without licensing a 2nd VIN. You *can* still use your MAF as well with the 1-bar Enhancement.
EC
Yeah I thought of that but there is an underlying reason for wanting to flash it this way.
Quote:
Originally Posted by EC_Tune
The calibration may be PCM specific. VCM Editor *may* balk if you have the wrong hardware (PCM) for the software (model year) you are planning on using.
Horist flashed my 2000 F-body PCM with a 2002 program and I haven't had any issues. I've been tuning it as a 2002 F-body for a year or so. This is in my conversion car so your situation is not exactly the same.
