How do you calculate offset and scalar for a 3 bar map?
Hello. I was wondering the formula or how to find the correct values for a Bosch 3 bar map 0281002845. Also I read the GM part # is 55206797. The one I went with is a 3 Bar TMap Map Sensor with IAT from here:
http://www.bmotorsports.com/shop/pro...oducts_id/1721
I seen on a few other websites people that used this sensor had 322.5806 (linear) and -8.05 (offset) for a 2007 colbalt and someone used 305 (linear) and 10.33 (offset) on an LS1. I would like to be able to see what one is correct.
Right now I have a 2 bar map sensor but running near 1 bar of boost causes the map sensor to max out if there is any boost fluctuation.
Any help would be greatly appreciated!
