Car goes into REP LSX
ill attach a small test log , but under moderate to heavy acceleration im pulling codes P0651,p2135 and u0109 car is a 2010 LSX based TT 427 camaro ( manual ) and goes into limp home mode aka reduce engine power mode. disconnect battery and clear codes and car is back to normal until the next hard pull . I was going to replace crank sensor next.
thoughts ?
1 Attachment(s)
log attached from test run
Attachment 115885
Codes indicate a wiring issue.
1 Attachment(s)
attached tune for camaro TT
I am looking to replace the crank sensor , car runs good under current tune. this is an intermittment issue that comes on after ONLY the camaro is warm and under WOT or near WOT , might replace the tps sensor while im at it ( car is 11 years old after all )
Check out the crank sensor like you were planning to, and the wires near the starter tend to get cooked on 5th gens.
