Confused on crank relearn does it work or not?
Still working on my 2019 f150 5.0 with Whipple gen5 stage 2 install. Shortly after installation i had a issue with truck and finally found a small broken bolt got caught up in bell housing and damaged relucter wheel.
After replacement i performed the crank relearn and it came back successful. However I still have code 0315 even after several drive cycles.
I have searched and found discussions on this from a few years back and the HP videos on how to perform crank relearn. My tuner says it doesn't work on HP and I need to take it to Ford or try a SCT device. I really don't want to go back to Ford they already nailed me for $1900 repl acing pcm for what ended up being the broken bolt.
What is the definitive answer on how to perform crank relearn?
