2 Attachment(s)
Throttle issue after ecm flash
have a 2000 silverado 4.8 that is being used for a swapped paired to a 700r trans, tried to set up for the trans and changed couple other things like fans, and vats and after the flash the engine starts and runs but wants to die when you try to rev it. here is the before and after of the little changes. someone please help , im a little confussed. also it shouldnt matter that knock sensors are not hooked up , right? cause those were taken out, not sure if i was supposed to do someting in ecm. please help.Attachment 137497Attachment 137498
