Whats the highest you can data log MPH?
Mine stops at 158mph....is there a way to log higher?
Bill@hptuners ?
Bill@hptuners ?
158 on many applications, it the pid limit in the pcm.
More vehicle info may help.
What does it say in Main Table (not gauges)?
Hpt should log as high as PCM puts out.
posting same time as Bill
2011 Zr1
I pulled all way thru 5th....
Also how do you set the speed to calibrate right.
I have nitto nt05r's 345/30/19
Tread Depth: 1/32''
Tire Overall Diameter: 27.36''
Tire Section Width: 12.48''
Wheel Diameter: 19''
Spec Wheel Width: 12.0-13.5''
Max Load @ Max Press: 1653 lbs @ 44 psi
Revs Per Mile: 759
Attachment 44159
Any way to add front wheel speed sensor for hp to log?
Setup a seperate PID to calculate speed from your RPM and tire height when you're above X mph?
